Router with VPN server
26 Feb 2007
I currently use windows 10 VPN server to connect to my office from home, could someone recommend a router with a built-in VPN server that I could use instead? I find W10 VPN a bit unreliable. I have been recommended a draytek router at around £250, is there anything cheaper around?
If it's for work VPN purposes do you have an IT dept there if yes speak to them, you could find you don't have to pay full price if anything.
Draytek would be the way to go.
If it's just a single person needing remote access then it would be easier to just run teamviewer on a PC at the office and remote in.
I'm sorry guys, I thought I'd sub'd to this thread.
Just to add some details -
It's my business, literally one PC I work on at a unit and a few network devices I'd like to be able to log in to.
It's a VDSL router at the unit which I want to replace and setup as a VPN server which I can then log in to using the windows 10 VPN client at my house.
I don't like the lag etc of teamviewer, I do have a logmein account I use on a few customer machines but I don't like working over it as it's nowhere near as quick as RDP.
Router would ideally have wifi, although I could easily put a tp-link access point of something in if it didn't.
MikroTik RB750Gr3 (Hex). About £45 and has hardware acceleration which can cope with 450Mb.
What would I use to connect to the VDSL connection if I used this? Also, I tried and failed to setup a microtik router previously so ideally I'd like something with a more noob-friendly UI.
The obviously choice would be a Draytek of some form, but they all seem to be around the £250 mark, I'll spend that if I have to but is there a cheaper alternative? Something running dd-wrt maybe?
Thanks for your help so far.
I’ve no experience, but perhaps someone who has could comment on an Asus router with VPN server as a mid price solution? Certainly cheaper than a Draytek and has an easier UI than Mikrotik. If your upload speed at your office is <20Mbps then it should be powerful enough to give a reasonable speed connection I guess.
Not what your asking but a Raspberry PI can be cheap alternative to a whole new router, can easily run openvpn-server although you will be limited by its processing power throughput?Maybe. But it would handle RDP and smallish transfers fine and it maxes out my home upload at 12mbit/s. Plus you can run other applications on it which is handy.
I've got 80 down and 20 up each end. I'd rather do it via a router I can buy and just setup but I do enjoy messing with RPi.
I'll have a look into the Asus option and the pi, I might just setup the pi and see how it goes if it isn't too much of a pain.
I have an Asus RT-AC3200 and use it with 2 static site to site OpenVPN tunnels. I'm on Virgin 350Mb cable (350/20) and find it more than good enough. The thing people forget with VPN's is the horsepower needed for on the fly encryption on the data travelling down the tunnels when using it direct to a router, hence why I upgraded from an Asus RT-N56U.
If you want an Asus option the RT-AC86U is nice - decent processor, hardware acceleration in the BCM chipset and well under £200
That will not even get into 3 figures doing a VPN
The manufacturer specifically states it will, they’ve even gone to the trouble of publishing the results with specific details of which encryption type/settings were used on the product page. Knowing Mikrotik, i’d imagine they aren’t going to do that without making sure it can perform exactly as advertised or they’d get slaughtered by the community. The issue tends to be that you need to use settings that benefit from the hardware acceleration, otherwise it’s just going to perform as well as every other router based on the same SoC.
Source ?
The same router will terminate the pppoe, there is a very steep learning curve with Mikrotik but they are somewhat of a Swiss Army knife.
You are thinking of the r2 version. The r3 (the real hex) has HW offload and will definitely do what is stated.
Yes I read the Microtik product page - that's only for IPSEC and 1400 byte packets - LOL, bit of a Daily Mail headline
The community forum I was alight when they released them. They are certainly capable, I appreciate you’ve interpreted the info in a negative way and I won’t try to defend the product any more than you are wrong.
Your grasp of the product goes about as far as your spelling of it.
