 - 30 Oct 2008
 - South
I would say it's probably the beginning of a coil pack failure. If not this then a fuel pump/fuel pressure sensor. Injectors would be wayyy down on my list of things to check.
Have you had it in to a proper garage to scan the codes? Surely these instances will have generated a code.
The garage that it went to checked the coil pack for misfires and said they were fine but I'm not sure they scanned for any codes, it was only a quick check in-between bookings so I guess I'll have to get it back in or take it somewhere else.
