What is this and how do I connect it ?
29 Dec 2012
Hi,
I picked up a used noctua U12SSEAM4 and it came with a clack cover over it with a cable connected but I dont know what it its or how to connect it.
some images below not very clear but hopefully it will be okay.
https://prnt.sc/kgsozw
https://prnt.sc/kgspmg
https://prnt.sc/kgsq76
kgsozw
Its a Phanteks Halos, you connect to a rgb header on your mobo or a phanteks rgb controller.
Thanks for the reply, I thought it was something like that, I have a Asus crosshair V! and I used the RGB header but it keeps poping off, ive even used the rgb cable that came with the board
Is this what you need?
My basket at Overclockers UK:
Total: £8.61 (includes shipping: £4.66)
It says it is for LED stips, but presume the connectors are the same on the Halo.​
Yes, that's what I need.
Man thats sucky, i thought they could be connected straight to a mobo header, so you either need a phanteks adapter or the controller to use them.....are they becoming Apple? :D
Must be, the more expense pack comes with once.
I thought so too, I connected it about 6-7 times thinking ive not fitted it right or its something else before i asked here.
Doe anyone know which items come with the adaptor, I maybe spend a little more and get the adaptor with strips or fan cover
