Wiring a PC Fan
Caporegime
12 Jul 2007
United Kingdom
I've ordered some high static pressure fans from a distributor and to my surprise, they came without a fan header and would therefore need to be connected manually, and perhaps soldered.
Where can i get this done? It is not something i feel comfortable doing myself and although i did try, i failed and it didn't work. I have 6 fans in total that need wiring, but I've got no idea of how i find someone, or a company to do it.
Appreciate any suggestions folks may have. :)
Man of Honour
12 Jul 2005
Aberlour, NE Scotland
It should work with a normal fan plug as long as the wires are in the right places, diagram here. I think Sanyo Denki fans may be intended for industrial use although there is no obvious reason why they wouldn't work with a normal 3 pin plug on them.
Caporegime
OP
12 Jul 2007
United Kingdom
I lack anything to solder them with, so would rather pay someone a few quid to do it for me. It's just finding a company or someone to do it.
30 Jan 2009
Aquilonem Londinensi
If you have needle nosed pliers, it's possible to crimp the pins, I've done it in the past. Pain in the backside though with 18 to do, but probably not worth shelling out £40+ for a half decent crimp. If using solder, but be careful not to foul the connector housing. A touch too much solder or a spike and it won't fit, it's really a case of less is more.
Hopefully there is someone on here that has the tool for the job and will help you out
22 Jan 2012
For soldering work you would need to find an electronics repair shop, there's not that many of them left now but someone there may have some soldering experience.
Caporegime
OP
12 Jul 2007
United Kingdom
Thanks for the suggestions guys.
I'm hoping a friendly soul at OcuK forums can help for a few quid, but if not i may have to look for an electronics shop in Norwich. God knows if ill find one mind. :D
Man of Honour
12 Jul 2005
If they are the same as in your picture then they don't need soldering. The pins crimp onto the wires and are then pushed into the plug until they lock. You can get a half decent set of ratchet crimping pliers on Ebay for less than £15. The ones I use are similar to these.
13 Jul 2009
Llanelli
I'd offer to do it. I've terminals, connectors and all the soldering stuff you could shake a stick at. I am however a very long way from Norwich.
Caporegime
OP
12 Jul 2007
United Kingdom
Thanks bud.
I could ship them to you and arrange a collection of the fans once you are done? Don't mind giving you a few quid for doing it either. I'll just mess it up if i attempt it myself :p
13 Jul 2009
Llanelli
Just realised there was a Spoiler...... thought this more complicated to be honest.
In fact it looks really straightforward.
A little shortening of bared conductor to around 2.5mm. Using a set of pointy nose pliers to fold the crimp around the bare conductor. Then if desired a dab of solder on top and shove in the relevant hole. I've done this hundreds of times for all the little PWM converters I sold a few years back. I only once or twice ran too much solder which was fixed by heating back up and flicking it off.
Not sure how else it could be messed up really. If you did, for example mess up a terminal they are available in their dozens on ebay for £1. The connectors like wise.
Just thinking that the cost of shipment both ways is completely unnecessary here. Even the cheapest of the cheap soldering iron could cope with this.
If you want to give it a go I can help you with diagrams or whatever.
3 May 2018
This of course assumes the wiring diagram is with the fans as to which wire is which and they are actually standard and as expected. PC PWM fans follow a standard, but are these standard fans?
Caporegime
OP
12 Jul 2007
United Kingdom
I didn't attempt a solder.
More than happy to ship and from you @Tealc if you can do it for me? I would rather do that than do it myself. :)
@PaulCa
I think they're standard fans, just with a slightly higher power draw (0.31a) than typical fans due to the higher rotational speed.
19 Oct 2002
Woolyback Country
Thats about 3.72 watts?
Is that a bit too high for direct mobo connection?How many you intending to connect to mobo?
Lastly, i assume they are to be connected to a motherboard?I ask as recently i swapped a fan in my new UPS as it was too loud Bog standard fan with a gfx type connector i had to mod ,anyway cables were standard colour but had to rearrange order to get them to work
Caporegime
OP
12 Jul 2007
United Kingdom
I have a 35W fan controller, they will not be connected to the motherboard.
I have 6x fans, 3 will be used in one system and 3 in another, both using the same fan controller. Should run them fine.
6 Jun 2008
Finland
