Hi there
Managed to get quite a few jobs done on the car today, plus more items arrived along with the new number plates.
So today manage to get done:
- Front upper and lower grills painted with plastiip to freshen them up
- Further cleaning on engine bay, decided not to paint inlet manifold but instead gave it some elbow grease and a real good cleaning.
- Carpets fully cleaned, seats all wiped down and then the interior trim all gone over with Meguiars interior detailor
- All the glass cleaned inside and out with Autofinesse glass cleaner
- New plates fitted
- Cup 172 badges fitted
- New gear gator fitted
Some pictures:
Still lots to do but the car is really starting to look better, also the car still has all the original glass which with a Cup 172 is very important as they featured thinner lighter glass to save additional weight. Only downside is the front windscreen is scratched from where previous owners must allowed wipers to become so deteriorated they scratched the glass whilst wiping on passenger side. Got the inside cleaned up, looking much better now and managed to remove all the residue from the tax disc holder.
The interior does not need so much now it comes up really nice and been a one owner car with low mileage it really does show as the seats and steering wheel show very little wear whereas these cars soon show wear to the seats and thumb grips on steering wheel.
All I want to do on the interior is get the gear number H pattern back on top of the gear stick as its faded.
The exterior still needs a lot of work, next step is to remove the side strips and bullets to give a real good clean behind those, along with cleaning the bullets and strips themselves, wax behind and refit. Then get a touch up kit and fix the loss of paint on door edges, thankfully only down to primer so no corrosion or rust, so get all that fixed. Then see if I can polish out the minor scratches around the car, followed by a clay, polish and sealant.
Also the fresher original cup springs arrived today and the Powerflex engine mount, just waiting on upper mount to arrive now so I can remove the old, clean that area up and refit new mount:
So brand new original dampers with much fresher springs, powerflex rear beam limiters/bushes will perfect the handling.
More updates to come.
