- 10 Jul 2018
- London.
What heatsets are people using? looking to spend upto £150
, I read that MS are showing a new range of peripherals (controllers, headsets and remote controls) at Gamescon in a couple of weeks, might be best to hold off.Damn, they look nice. Shame on the xbox it's restricted to stereo.I use the PS4 gold wireless headset, I read that MS are showing a new range of peripherals (controllers, headsets and remote controls) at Gamescon in a couple of weeks, might be best to hold off.
Just to clarify, wired headsets on xbox typically plug into the controller (always worth checking on the ones you decide to get to be sure). So don't worry about where your xbox is. Just whether you can handle having it go into your 3.5mm jack on the controller. Wireless are totally wireless.Thanks for the replies,
I guess i would be looking for wireless as the xbox sits behind the TV at the moment,
I picked up a RIG 800LX from Plantronics. Pretty good quality and comfortable for long sessions.
https://www.plantronics.com/gb/en/product/rig-800lx
