- 12 May 2011
- Southampton
Hi everyone
I am building a DOS PC (here is a short build log). I bought a sound card. It doesn't say what manufacturer or model it is, but the chips it has are an Opti 82C924 and Crystal CS 4231A-KL, and also a Yamaha OPL3 chip. I have identified a number of cards that it could be (i.e cards with the same chips) and downloaded them. I put all of them into a folder each in C:\DOS\Drivers and then added the following Autoexec.bat commands:
SET SOUND=C:\DOS\DRIVERS\TYPHOO~1
SETBLASTER=A220 I5 D1 H5 P330 E620 T6
However I don't get any sound, with any of the drivers. I understand that drivers weren't like they are now, and would work if they picked up the relevant chip rather than ID the actual manufacturer/model of your card and cancel if the right one wasn't detected.
I have a CF card so it is easy enough for me to dump dozens of drivers onto it from my XP PC and try each of them in turn.
Or are my Autoexec.bat commands the problem?
Annoyingly the BIOS on my board is very limited - I can't change or see any IRQ values!
I have to have SET SOUND pointing at the general driver directory "typhoon", not the sndinit sub-directory where setsound lives. As such I have to trigger setsound manually. When I do this, the sound is veeeerrrryyy quiet (not amplified basically). Any ideas why this could be? Also the soundcard utility (probably made for another soundcard, but detects the chips and volumes easily enough) won't save any setting changes (e.g. disable the gameport to free up an IRQ).
