Other people's loo brushes
I used to hate using the drain rods, right pain in the arse.
You are doing it wrong! ;)
The guy I got it off said to be careful as it could easily strip you to the bone if you're not careful, obviously I haven't tried that but I believe it could.
Like compressed air, High pressure water is potentially very dangerous. You also need to wear face protection. Not so much because of the water as such. Just that you donrt really want to get somebodies Richard hitting you in the eye!
What the hell is the op eating that he needs to “brush” every time?
Using the loo brush is the nuclear option after everything else has failed.
why do letterboxes have bristles why must the post be brushed
surely letter box has an inside and outside flap with a spring to hold it closed so the brushes aren't for the wind.
You only get one outside flap and inside bristles, its if mister postman has not washed his hand after going the loo. Its more hygienic as you don't want postman pat penetrating your safe space with itchy bum nail. :D
