Why the hell do car manufacturers do this, or are even allowed to do this?
The fact that if your engine/electrics on a car fail it can affect your brakes is insane.
As a mechanic since the early 80's. I am
 horrified at the failure modes that are possible on modern vehicles.
I have posted on this matter before.
Recently I had a customer with a VW Passat that experienced an EPS failure.
This happened suddenly and completly without warning. She was very lucky not to have been killed (Not to have killed somebody else)
Really!
I may be getting on in years but I have always done manual work so my upper body stregth is considerabe.
My Arms are larger than my GF's legs, (something she finds rather thrilling actually
) She has a knee support thing when we go out cycling and I cant get it past my wrists! I have oil and antifreeze delivered in 200L drums which I have to roll to where I want them and then up end them. Oil is easy enough but Antifreeze is a little Bitch. Upending a drum of Antifreeze is a 250Lb+ dead lift!. I only mention this because...
With the EPS non-functional, I found this car undrivable.  Had the EPS decided to die while she was negotiating a corner or a roundabout, there is no question in my mind that she would have completely lost control of the car. Hell,
I would have done!
This is
SIMPLY NOT ACCEPTABLE and I, like you, cannot understand why it is allowed under construction and use legislation!
