8700 wont go above 3.5Ghz with turbo on
19 Jan 2005
Cambridge
I've just built a new PC with an i7 8700. I don't plan to overclock so I went for the cheaper non-K version with the understanding that it could still reach 4.6Ghz with turbo mode enabled. But I'm unable to get it to go over 3.5Ghz with prime95.
I did some research and found that if all 6 cores are under full load then it can't reach 4.6Ghz but it should still be able to reach 3.8Ghz. I tried running prime95 on a single core and it got to 4.0Ghz but it's still much lower than I would have expected.
I had some problems with the memory on my motherboard. The computer will not POST if the RAM is installed to either of the first two sockets which I think is caused by a bent CPU pin, so I'm using the last two sockets in single channel. I'm wondering if these two problems may be connected?
12 Feb 2014
Somewhere Only We Know
Quite possibly, one pin could be shorting another pin out if its touching it, I did advise in your other thread that you try and straighten it up.
However, I'm running a Ryzen 2700x and the way the turbo works on that is dependant on heat, so the more stress you put on the cpu, the more heat it generates, the slower it runs, in gaming it often hits turbo speeds of 4.35ghz, if I run prime95 I hits between 3.9ghz to 4ghz, this could be whats happening with yours too, easiest way to find out is run something less stressful, a game etc with an OSD so you can monitor the cpu speed.
13 Aug 2012
The boost on that cpu is 4.3 when all cores are loaded 4.6 single.
Try manually just setting clocks to 4.6 or turn on mce.
Also what cooler are you using? you might struggle with the stock one.
OP
19 Jan 2005
Cambridge
I don't think it's heat as I haven't seen it over 50C at full load. It never goes above 3.5Ghz when gaming either.
I would try and bend the pin back but it's so small I can't even tell if it's bent or missing. I'm going to see if I can return the board now that the bank holiday weekend is over.
26 Oct 2006
isn't MCE only for K CPUs? you can's see it in bios or enable it
when i had the 8400 i couldn't see the option but with 8700k i can
13 Aug 2012
I have "ASUS MultiCore Enhancement" which is set to Auto, the only other option is Disable.
Auto should mean it's on. Maybe try it off see if it makes difference and then try back to auto.
It could be another issue. Are you using XMP for your RAM? If so I would try turning that off and see if it makes a difference.
Also are you 100% sure it's an 8700 in there? Is it showing all 12 threads in windows.
OP
19 Jan 2005
Cambridge
XMP is turned off but I have tried with it on as well.
It's definitely a 8700, it says in the BIOS and in Windows. Windows shows 12 graphs in the task manager if I choose to show logical processors.
13 Aug 2012
Ok well if nothing worked I would try a bios update.
12 Feb 2014
Mate, honestly, try and fix that pin, ive highlighted it in yellow in your picture what looks like the pin to me out of place, just get some fine tipped tweezers like mine, and gently pull it back into place, you cant make it any worse, even if you snap it off, you'll still have use of those 2 ram slots that are working now, when you fix it you'll wonder what all the panic was about, you may need a magnifying glass too or if you have a camera that does close macro, you can use the screen as a magnifying glass, but that pin looks like its touching the pin above it, without a pin out of the socket which you can google. realistically right now if they are touching, you have 2 pins not working properly, one shorting the other and that could cause all sorts of problems, even eventually kill your CPU.
I brought this dental set, cost me £3.99 off ebay, perfect for those sorts of jobs, but I brought it for making coils a wicking etc for my vape kits.
5 Dec 2010
Solihull
MCE doesn't work with non-k cpus.
Some OEM boards limit the tdp to 65w, which makes the 8700 stick to it's base Freq. In one of the the Adored TV videos, he found this with a medion prebuilt pc.
28 May 2007
Intel pulled a fast one and weaselled out of the the turbo on offer just after coffee lake released. The max clock is 3.2Ghz anything over that is out of spec.
See this thread.
https://forums.overclockers.co.uk/t...-multi-core-turbo-boost-frequencies.18795843/
