- 24 May 2011
I’m tempted to do it to my brand new 8700k, but I’m a little worried to say the least... does ocuk offer delid CPU’s or is it worth the risk doing it myself?
If you buy one of our binned ones it's delided already .. If you want to delid yourself use our delid tool. We used it for thousands of cpu without any problem at all.
Did mine, was also cautious as you are but turned out to be simple. Well worth doing too.
Most 8700k are actually 4.9..... Glade you tested thousands and can confidently comment.....
Cool what did you use to glue the HIS back and to scrap the old glue off?
RTV gasket black stuff, the tiniest amount everCool what did you use to glue the HIS back and to scrap the old glue off?
Careful use of a blunt/soft tool like a credit card for removing.Cool what did you use to glue the HIS back and to scrap the old glue off?
What does a nude CPU look like? Any CPU porn of one with it's clothes off? (delidded)
Decided to finally take care of business and de-lid. I think this is the only way i will be able to look my friends and family in the eye again.
Ordered the tool and der8auer tool and thermal grizzly liquid metal from here. I won't be regluing the IHS. I've read some people talk about putting nail polish on anything exposed should the liquid metal get off the die. Does anyone bother with this? Also what is to prevent the liquid metal migrating off the die. I assume it's because it's such a thin layer?
I'll let you know how i get on. I'm on a 7700k currently getting 5 Ghz and gets to 85 max at gaming averages high 60's. Have my fans and pump all set to max so be nice to bring that down a bit and maybe get to 5.1.
