So, you're looking for a new car, you set your budget and have a rough idea of how much your own vehicle is worth - more than 7 years old, over 100k on the clock etc.
You're just about ready to go and look at a potential new car or two when your own car throws up a yellow warning. You ask the car what is wrong, it tells you and you investigate.
There is an issue, however all the documents tell you that you'd be hard pushed to know there was a problem unless the light was on. You confirm, you cannot "feel" anything wrong with the car.
The light starts being intermittent. It'll come on, you'll drive around with it for a week and then it'll go out.
You drive up to the dealership, look at new cars but before doing so you plug in your own device and clear all current errors, no more warning lights and no errors listed.
Car is inspected, everything is taken into consideration and you're given a price you're happy with.
You drive around for another week until it is swap-over time, light stays off until the drive down to the dealership when it comes on again.
You park up, say your final goodbye to the car and at the same time clear the error once more.
Deal goes through, you leave your car behind and you drive off in your "new to you" vehicle.
Morally:- Pretty low. Really should have let them know as it'll probably reflect in the value etc.
Legally:- ???
Cheers.
Legally:- ???
Cheers.
. What did the code point towards? If it was something unimportant then i wouldnt worry about going to hell, stealerships screw people over all the time to try and make a buck, it levels the playing field slightly it happening the other way round. I cant help but think they will end up doing exactly the same though and sell it on like that....
