- 22 Aug 2004
Mine has a manual release for emergencies.
So maybe they have a rachet system.
That of course means if the battery dies you aren't going anywhere and can't even be towed.
And to your second point... "yet".
How do you put your AC into drying/dehumidifying mode without cooling the car down?
How do you vary the air temperature to maintain a constant internal temp without having to constantly adjust while the outside temp changes and the engine temp changes?
Why are you so critical of something you obviously are not familiar with? There is no ratchet and no cable. The handbrake actuator winds the caliper in and out. You even need to manually wind it out yourself when changing the pads, for example.
If my battery dies such that it won't even operate the handbrake motor then it's not starting the engine either and I'd be looking to put a new one in the car before using it. Either way you can't tow my car anyway because its an automatic.
I've had them for 4.5 years now on cars up to 6 years old... when exactly is it going to fail and leave me stuck? And why? There isn't much to go wrong!
Meanwhile my E39 manual handbrake was a total joke..
Automatics can be towed in Neutral. If for some reason the manufacturer does not recommend that then most towing companies will lift the driven wheels onto the towing mechanism. In the case of a jammed handbrake they would need to also put trolleys under the rear wheels to and these are most likely rare
When you take the battery out, the car rolls off.
Then the software crashes you can't engage or disengage the handbrake.
When you have an emergency problem such as brake failure the automatics might not let you use the handbrake.*
The automatic handbrake is "ON" "OFF" no variability.
The mechanism is poor and underpreforming. There are many, many more cases of electric handbrakes failing and cars rolling away than physical cables snapping.
Drum brakes are better suited to the task.
You can't do hand brake turns on a track day.
* try this as a test. Assume your battery is flat and a friend is pushing you down a hill. But the car still won't start. You apply the foot brake but as your brake servo is now completely empty the brakes don't work properly. So you engage the handbrake... but... oh... what's that? The automatics won't let you? Oh, what a shame. Even if they do let
Don't most autos have an "emergency brake", because you can't engage park while rolling so if you had a brake failure you can use it.
"Brake failure" BTW... Try this. With the engine off, pump the brake pedal to deplete the servo. Now roll down a slight hill and try and stop the car. Most car manuals specify that if the engine fails while driving to brake ONCE to a complete stop. This is why. Without the brake servo it can be very hard to stop the car without it.
My handbrake operates on the driven wheels. My gearbox will pop out of neutral and park into park if left idle for a period - it's being towed on a flatbed if its broken down irrespective of whether it has an electronic handbrake or not.
A manual handbrake would add zero benefits to my car and only disadvantages. There is nothing wrong with them!
I often find myself 30/40+ car lengths in from of them just sitting in lane 2 and relaxing. Makes me laugh!
agree .... there's a dashcam 'vigilante' back down the thread condoning that .. someone bridges the two lanes to stop them 'filtering'And a proper pet hate - people who use a closed lane on the motorway (red X) for half a mile after it's showing as closed, then expect to push back into lane 2 30ft before the accident/broken down vehicle. It's closed for a reason you ****.![]()
If you've seen Mission Impossible: Fallout, you probably noticed that BMWs ... Instead, the film's star car is a classic 1986 E28 BMW 5 Series
Your Audi had an old mechanical selector.
How do you leave an auto in gear?I used to prefer the manual handbrake, as doing handbrake turns is great fun!
However, i've been nipping around in a Seat Arona for the last two weeks and I quite frankly miss the electronic handbrake. As posted above, it's just about getting used to it.
Also, for those who say "but OMG it will roll away111" LEAVE IT IN GEAR!
Disclaimer: I've done about 4 handbrake turns in this Arona, but overall, electronic handbrake is so much better. Especially if coupled with an auto 'box.
TBH i wasn't sure how park worked.It gets left in park..
Various methods but generally all aimed at some sort of ability to prevent the output shafts from rotating.TBH i wasn't sure how park worked.
