So around £1299 when it releases here then?
As a gamer AND professional graphic artist, given the F version does not comprimise on color reproduction quality, and on top of that it comes with higher refresh rate and future proof connectivity such as DP1.4 and hdmi 2.0. I think it would be unwise to support nvidia screwing people over with the super expensive g-sync in order to get 144hz and true 8bit color depth and latest connectivity, so all in all I think the F version is overall a better product and cheaper as well, and my conclusion is coming from a person who wants to use a Nvidia GPU with it.
Also if you really want your nvidia card to work with free sync, there are hacks that will enable that.
https://www.tomshardware.co.uk/use-amd-freesync-nvidia-gpu,news-59067.html
I hope to get one out this week if I can, I have the sample unit in my warehouse
The idea that having a DP1.4 connector somehow future-proofs the monitor is slightly ridiculous. You buy the monitor with the capabilities it has at the time of purchase, and that's how it will stay until discarded. Having a more modern connector will not somehow magically improve the monitor down the road. There simply is no "future-proofing" by way of the connector.As a gamer AND professional graphic artist, given the F version does not comprimise on color reproduction quality, and on top of that it comes with higher refresh rate and future proof connectivity such as DP1.4 and hdmi 2.0. I think it would be unwise to support nvidia screwing people over with the super expensive g-sync in order to get 144hz and true 8bit color depth and latest connectivity, so all in all I think the F version is overall a better product and cheaper as well, and my conclusion is coming from a person who wants to use a Nvidia GPU with it.
For HDR, a 10bit panel (or 8bit+FCR) is mandatory.I think someone pointed out here that the 10bit panel is nothing you will notice in games. So it motivates you since you work with graphics but for me as a pure gamer the GSync lures more.
Yup, you misworded If reduction to 6bit is in fact the consequence of "overclocking" the G-SYNC module (or any other similar tricks) , then I completely agree... that would be crap.Perhaps I misworded my point. Let me try rephrase it. The Gsync that comes with this display is outdated in the sense that it can only supply you with 8bit color depth at 100hz, which seems to be the absolute limit it can take in terms of maintaining image quality, should you wish to overclock it to 120hz, you will likely be turning the image quality into something more in line with 6bit color depth. For me that is unacceptable for such a high priced monitor, especially now that the freesync in comparison offers connectivity that makes the refresh rates (144hz without any compromise to the 8bit color depth image quality
On a real HDR monitor (not the DisplayHDR 400 rated F version), you most definitely will notice a huge difference in gaming, so in that way, a 10bit panel is something you'd want for gaming, but only in combination with HDR.
Without HDR, most AMD and nVidia cards would refuse to even send a 10bit signal, making any 10bit panel entirely useless for gaming.
4K/60 is 498M pixel/sec demand. 3440x1440/144 is 713M pixels/sec demand. 43% greater demand for the latter. The latter having the same requirement around 100 Hz as 4K at 60 Hz/FPS.
So assuming in triple AAA on Ultra 2080 Ti did only 60 FPS 4K (I suspect it will be more around 75), yes you would need to turn some setting down. If you use 4K 75 as the base metric, it means you could run 3440x1440 up to ~125 FPS on Ultra. I think this last scenario is realistic.
Now there will be some +/- to this as there are some rendering dissimilarities between 16:9 and 21:9 field of view.
If I had to guess, I'd assume you're right, but how do you know?The display does NOT drop down to 6-bit when running 120 Hz.
I think the image quality drop that you will experience with the gsync version is something similar to the problem people will see with the highend 4k hdr monitor from asus and acer.
https://m.hexus.net/tech/news/monitors/119354-g-sync-hdr-4k-monitor-images-softer-blurred-144hz/
