So I know that Shamrock's gear has arrived - did anyone else's spexcel orders turn up yet? If so what did you think?
Got my "2018 UPDATE SPEXCEL CYCLING BIB SHORTS Training or race cycling bottom with Italy high density 3D cut pad free shipping" yesterday.
Meh.
I suspect that a £25 bib from Decathlon would be comparable.
The Spexcels are thin lycra, and I possibly should have sized down from the recommendation on the size chart on their store page. They're not baggy, but the fit is a bit looser than I'd expect. I'm 187cm, 95kg, and (I've just measured...) have 65cm thighs. I ordered size 2XL.
Theres some reflective dots on the legs which are a nice feature but a couple of dots are missing from each leg which spoils the effect a bit. Nevertheless they look smart, and are completely free of external branding or extra colours.
The gripping on the inside of the legs is nice - quite a wide generous band - I just wonder if it might be sweaty in use.
The chamois looks good and the main part seems decent. The front is very thin, and together, that, and the thinness of the lycra means these don't offer the same, errr, "frontal embrace" (! ?) as other bibs I own (from Rapha, Sportful) and others I've had in the past (from Santini, Campagnolo). It results in a slightly disconcerting feeling of near-nakedness. Certainly anyone riding with you will know which way you hang, and precisely how far.
Personally I like a degree of compression in my bibs and so thicker lycra and a more snug fit. I'm going to Decathlon at the weekend and will have a look at their bibs - they have a £25 pair and some for £45. I'll try to post some comparisons afterwards.
(a heads-up - on the Decathlon website at the mo they have some size L £25 bibs reduced to £12! -
https://www.decathlon.co.uk/road-c-500-cycling-bib-shorts-black-id_8402928.html)
