FACEPALM
You didn't read the instructions. That is not the way liquid metal is applied.
And you will not find ANYWHERE ANYONE advising that method for liquid metal
Qtips! just lol come on chap you are a Yorkshire mon
i use a few Johnson's on mine lolzThat's right I used the brand Qtips ??
Please enlighten me to how it should be done
FACEPALM haha
How you applied it?
small blob and a few Qtips
You didn't said you spread it.....
why would i be using Qtips(cotton buds for pooley), if not to spread it.
your tried too hard to make a funny.
FACEPALM
You do understand many in here are not living in Yorkshire or in the same island?
Also GN video uses twice as much liquid metal than is needed for a completely different appliance.
Panos it really doesn't matter how he applied it, he applied it near/on aluminium.
FACEPALM
2. Applying Conductonaut thermal grease Mount the included tip to the syringe (Figure 1). Apply a pinheadsized amount on both, CPU and cooler (Figure 2). Spread the thermal grease on both surfaces with the included cotton swabs. An increased contact pressure of the cotton swab might ease the application. Now mount the cooler.
He said used a blob and qtips how should I know what qtip is? swabs or cotton buds would be easier to understand.
So you are trying to say that you went with a giant red FACEPALM and stated that you will not find ANYONE ANYWHERE (ftfy) advising that method for liquid metal. with out even knowing what he was talking about.
DONT BELIEVE A WORD OF IT.
People are too obsessed with temps.
Better to run a couple of degrees hotter than use extreme options like the one in the OP.
I believe that LM can't be used below a certain temperature, for some reason around 5°C rings a bell.In more extreme cooling setups another matter.
