- 1 Jan 2003
- Derbyshire
I was wondering similar. I wonder how much pressure would be required to get 13l/min (decent combi flow at 35c) through the internal diameter of 10mm pipe work!
Depends what your supplying water too, the bathroom has 15mm to the bath then a 10mm from that to the sink. Kitchen has 10mm as far as possible.Disadvantage of that surely is that you'll overall be reducing the flow rate (due to increased friction)
I know what you mean though, my shower takes a while to get hot, but the pressure/flow is good!
moved by boiler from an unheated attached utility to an indoor cupboard
seems much better now its indoors, quicker hot water + heating and lower bills
indoors is 18deg, utility used to get to low single figures - can't see how a heating device works better in those conditions
It's got naff all to do with the size of house. It's all about how you use hot water.What size houses/flats are your combi boilers heating? We have a two bed terraced house and are thinking of changing the boiler to a combi as we will be able to free up space in the bathroom for a shower, but we have heard they only work well up to a certain size house?
Basically a combi will only serve a single output at a time. Two taps is no problem but if someone is having a shower and a tap is turned on the flow can drop considerably.
But it's not always the case of you take cooler showers like me, and you have say a 32kw or bigger boiler you won't notice a tap being turned on because the boiler wasn't working at max to begin with.
It's only an issue if the boiler is at max and someone demands more, an easy way round this is to not have the hot water set higher than you need it.
I have mine set to 50c so even with taps fully open it's often not at full power.
Done people just like to hate on combi boilers, if you understand how they work and their limitations it's easy to get the best from them.
