if your ram/case allows it, the Pro - push 5ghz![]()
Hey, comparing these 2 coolers, if trying to get a 8700k to 4.8ghz or so, will either do the job or shall i get the pro?
Dark Rock Pro 4 is about 5c cooler than Dark Rock 4. Dark Rock Pro 4 is 163x136x146mm in size with 7x 6mm heatpipes, 1x 120mm & 1x 135mm fans while Dark Rock 4 is 159x136x96mm with 6x 6mm heatpipes and 1x 135mm fan.
What RAM do you have?
Any computer system needs the case airflow adjusted / optimized to components being used .. and almost all cases either come with garbage fans or not enough fans so at the least additional fans are almost always needed while many need all new fans.
What RAM is 'this ram'?The dark 4 can’t clear this ram.
https://www.overclockers.co.uk/be-quiet-dark-rock-4-cpu-cooler-hs-01d-bq.html
Not sure if the pro could
If I know what RAM it is I might be able to tell you how tall it is.![]()
Lol
https://www.overclockers.co.uk/team...4000mhz-dual-channel-kit-black-my-098-tg.html
I have this ram with dark 4. Had to use dims 2 and 4 to make it work.
Not sure how the dark pro 4 would fit?
from memory when buying that ram with pro 4, it would not fit. However if you are willing to bend a few of the fins then yes you can. But best to double check.
That stuff isn't RAM, it's hi-rise condo stuff.Lol
It's 47mm tall .. about the tallest RAM there is.
Now, what case and motherboard do you have? I might be able to suggest so top tier extreme cooling coolers that will fit. I assume you have a graphics card to go in too?
Haf X has 190mm CPU clearanceI know...it’s crazy. Got a haf x so clearance isn’t an issue. Don’t want to go AIO or water. Would like to stay on air.
Gigabyte z390 pro but it’s going back.
I'm currently looking at g skill trident 3200hz cl14 altho not sure if im throwing away money with that
Haf X has 190mm CPU clearance[QGUOTE="Robert896r1, post: 32202271, member: 207553"]I know...it’s crazy. Got a haf x so clearance isn’t an issue. Don’t want to go AIO or water. Would like to stay on air.
What case are you using? Sorry if you post it above. Thread is getting confusing with you and Robert896r1 both asking questions.I’m not sure on Mobo as waiting for reviews but likely the z390 gigabyte ultra Mobo with WiFi. I can’t find many cl14 3200 ram.. unless I go for lower profile cl14?
This is so confusing haha![]()
Define R4 has 170mm CPU clearance so will clear most any cooler .. as long as RAM is not too tall or fan fits behind RAM.Shorter RAM can be same performance spec as tall RAM, it's just not as easy to find. I don't know what prices are like. It's been a few years sense I last had to buy any.![]()
