- 29 Dec 2009
I had something like this a month or 2 ago, following a Focus ST Estate. Started having a bit of fun with it (which they encouraged by trying to get up my chuff) then later on down the road I pulled in to get fuel, the Focus then pulled in for me to then notice it was 3 undercover policewhoops. They were looking at my car & probably checking insurance as it's all modified and stripped out.
They didn't say anything however and I heared nothing about it. Considering I was close to double the speed limit I thought I was screwed. Lucky escape.
The problem is, if you had a dash cam, and he decided to book you.. he would be in hot water as he shouldn't have been doing those speed without his lights going... So yes, what else are they going to do?Happened to me once when joining the M25 on a long sliproad. I gave it a bit of power (still well within the speed limit) and a silver S3 pulled out in front of me and also booted it. I thought it’d be funny to stay with him all the way onto the motorway, which I did, all the way up to about 120MPH at which point the blue lights came on in his rear window and I thought I was in rather a lot of trouble.
He didn’t even bother stopping me, just pulled alongside me once I’d slowed down and gave me the “you ******* idiot” look. The same car pulled a friend of mine a couple of weeks later and was a lot less forgiving, think I was very lucky that day!
most Hyundai'sHaha, sounds like he was just ****** because Hyundai's can't keep up with any thing.
As I've previously said, yes they can. Under quite a few circumstances it is operationally better to run silent and dark. Usually for evidence gathering or whilst tailing a suspect with a violent flag and awaiting backup arrival to pull a stop.The problem is, if you had a dash cam, and he decided to book you.. he would be in hot water as he shouldn't have been doing those speed without his lights going... So yes, what else are they going to do?
They are allowed to run "silent & dark" and exceed the speed in certain circumstances.
Maybe not in this circumstance but it is allowed.
It's when you don't notice they tend to get upset. A hard stare works wonders, and is less work and hassle for all concerned.
I've seen it a few times around the M3 to A303 transition heading to the South West - usually can tell who they are eyeing up long before they pull em and definitely at times doing quite some speed without lights or siren.
Probably as much as anything it is a comeback thing - if there was ever any questions over it they could say they gave a warning, etc.
Great 1st post on a computer forum, I think they have to pull you over to issue a ticket in this instance, normally it would be a static gun on the side of the road as I'm not sure of the accuracy of a radar gun from a moving vehicle.
They don't need to pull you over, a NIP in the post within 14 days would suffice. They also don't need a radar gun, following you for a designated distance and their statement is enough for that.
Sounds like that might fall apart if challenged.
