Roland V-Combo VR-09B
Thanks guys
I want to add some trellis and a climber or two on that right fence line, my neighbor is cool with it (I said I'd keep it lower than the back fence which is 8ft high). I have zero idea how I attach trellis to a close boarded fence as the posts don't go higher, the panels are 8ft wide not 6ft, and nothing atop them to add it to. Not helping is that the fence line dips downwards by about half a foot from the front to the back over a span of about 7.5M.
I'll probably take this question over to the home & garden section at some point, but in the off chance someone here has a clue on where to start I'm all ears. At the moment the best I have is stepping the panels down the garden between the larger fence posts, and then adding a larger trellis panel directly onto the posts so they go above the fence line.
Re-done the garden recently so I guess this counts
Before:
After (sorry did not take the same before/after angles. To the left on the before was simply more grass):
Looks awfully Fancy, I bought an old M audio Oxygen 49 for pennies from eBay last year, recently bought an M Audio SP2 Sustain pedal from the forest, lovely quality.
Only just started using mine since finding a website called multiplayer Piano, and jumping from room to room jazzing up Baby Shark and getting banned xD
New Living Room OLED TV.
Are OLEDs meant to be sharper than other panels?Should an OLED be that blurry?
@HungryHippos what makes it special, is it just the bottle??
