Caporegime
- 9 Nov 2009
- Planet Earth
I will still play the BETA I paid £1.49 to gain access to for 9 hours this evening then the next 2 sessions. Doubt I would ever buy even if its £5. Mainly because its so poorly conceived but also the setting just does not suit Fallout. Its now more of a generic location than anything else. The rural setting just does not fit into the Fallout universe very well. They should have made it vast destroyed cities & towns like 3,NV & 4. I suspect the main reason its in the countryside is because it was so much cheaper & faster to create the game world
This is using from what I can see so far about 95% of the exact same graphics as Fallout4 for the models & buildings which is so cheapskate. Bethesda have created very little new graphics apart from the actual floor of the landscapes & the trees. If the game looked like a 2018 game should look like it would be slightly better but it looks way worse than Fallout 4 ever did something is also off about the filters used to soften & blur the image. The mist & smoke filters are too overpowering right now to hide the low resolution of everything.
The weapons are really terrible as well so annoying it takes forever to reload after a single shot is so irritating. In the near future its set in I find it hard to believe they did not have access to weapons which fire a lot faster this is clearly done to slow down gameplay & extend the gameplay time a lot.
Tonight I will be concentrating on just exploring the game world going to the ends of the entire map looking for interesting building & to see if there are any underground bunkers whatsoever (I do not think there are any large underground installations in this again probably too expensive to create) & avoiding all combat.
Another real problem I saw in yesterdays BETA session was some numpty moved his base camp to a sneeky location around the corner from a ghoul spawn point so they could sneak in & take the loot from my battleSo I am fighting loads of ghouls which is hard enough without VATS & with the crippled weapons so this numpty pokes his head around the corner & I headshot him
as how am I supposed to know someone would be stupid enough to put their camp right next to this location
so then this player follows me around for ages trying to engage me in a fight I did not want so in the end I have to quit to get another server to avoid them! Ghouls animation is also shockingly bad as are most of the enemy animation cycles. They jump tens of frames & appear out of nowhere or get stuck in the air so you cannot shoot them which means you easily get overwhelmed with no way to fight them off leading to yet another respawn point & tedious click on every single item you want to recover from the respawn paper bag!
There are also plenty of other players who just want to mess around & try to lure enemies from their battle to you the MMO feature should be disabled if you want Solo its leaking to much into Solo play with no way to disable. On Xbox1 you can ignore all players on your server (you have to click every player 1 by 1 to do this though no global ignore all button) on PC they have not enabled this feature yet.
In its current state its barely an alpha needs another 6 months to just polish it further then another 12 months to improve on that as the game world is so empty feeling & lifeless. As it stands its going to get absolutely slaughtered if they persist with the release in 2 weeks![]()
Thank you very much for the objective assessement of the game in its current state.
