Hi,
I want to downsize my current case (ATX).
Going to use either my current mITX or new mATX boards with it, and want to fit 2 240mm or preferably 2 280mm radiators to it.
The only case that comes close to my requirement is the NZXT H400i which fits such radiator in the front but there is no spec for the top of the case, even if there are holes and the place to fit another radiator.
Has anyone used the H400i with dual radiators setup, otherwise what other case could be an option?
(please no midi towers options).
