*** The Official Battlefield 5 thread***
Still some LOD issues on most of the maps, zooming in via iron sights causes some significant pop in of objects in the distance.
Also had a bug last bnigh on the 32v32 game where no one could revive. Yes.... NO ONE.....
Made sure you turn on render future frames. Helped me a lot!
This seems to have worked, hope it sticks.
Option is unavailable for me in fullscreen mode though but borderless it lets me turn it on.
Having it set to off should'nt gimp your GPU 50% though, else they should just call it Economy mode.
I'm quite confused, as I have render off and have no issues but everyone else get's them.
Glad it's working though. :)
Setting the graphics to custom mode also appears to provide an FPS increase as well.
Worked like a charm last night, 2560x1080 at default settings but I turned all the motion blur and other video 'effects' off. I have an MSI 1080 ARMOR and it was locked at 60fps no problem with VSync on. I haven't had any bad net code issues or anything either. Overall its been very solid.
thanks for the invite wes ! wow these EA guys. get a free ten hrs yet you cant activate it without adding credit card details. :rolleyes:
Damn, won't be able to until im home later today :(
That's fine mate - will treat it as first come first serve; drop me an invite when you're home later.
Invite inbound :cool:
Would love one if you have one left?
Accepted to you guys but says you're both ineligible for an invite :( from the EA FAQ:
There are a few reasons why you couldn't invite someone to try Origin Access. For example, they might already be a member or they may live in another region that Origin Access isn't available in yet. And, of course, if your friend uses a Mac they won't be able to try Origin Access.
