Macbook 12" "vibration"?
28 Jan 2011
Hey guys,
Recently noticed when I have my MacBook on charge, there is a little vibration like sensation when touching the chassis?
Soon as the Mac is unplugged it disappears :confused:
Yup, exactly as said above. The adapter doesn't come with a grounded lead any more.
Yep it's normal. The 3 pin plug that slots onto the power brick doesn't have a ground pin connected whereas the extension cable variant that came with older MacBooks does. This article explains why and has pics of what I mean: http://garethhayes.net/apple-power-plug-not-earthed/
It's normal and won't cause you any harm. Just a bit weird when you're not expecting it but if you want to stop it then get one of the Apple extension cable plugs.
It can tingle a little if you ground yourself on something, especially if you're skin has any moisture on it
Feels like licking a 9V battery.
