- 18 Nov 2018
Hello.
I'm new here hoping to solve a problem I have somehow.
So recently I bought a Gigabyte Aorus GTX 1080ti Waterforce WB Xtreme Edition (quite a name!) used from a guy locally. It's fairly new, registered under a different account and has warranty till 2022. Irrelevant information but just to show how recent it is.
So the guy did not have accurate pictures of the card and when I got it it has black debris like stuff stuck on the block behind the window. I will provide a picture.
So I would really appreciate any suggestions on how to solve this. Is there any cleaning solution I can run through the loop or anything? Opening the block is out of the question since I read it's not possible without taking apart the glued front fascia. Plus I don't know if it would void the warranty (if I had any in the first place)
I have a relatively strong pump, xspc photon 170 res/pump combo but even at max for days, they won't budge. It's making me really sad that after so much time and a good chunk of money I finally added a GPU to my custom loop and this happens
Thank you
Phil
Thank you
Phil
