Hi,
Sorry no deals on Noctua they would not help all.
Just non digital, as we're short on stock on the digital versions.
He said mentioned ahead that he was unlikely to get deals for the Dynamic, but possibly could get deal for its uglier non-identical twin brother
Cheers Robbie,
I'm looking for a replacement rear fan for the Evolv X. I'm planning on moving the 3 included fans to the front of the case and replacing the rear one with a high air flow fan. I'm looking for something quiet and ideally white / grey so it will look good if I put a Halos Digital RGB Frame on it. Any suggestion?
Well the fans in that case are the PH-F140MP which we are currently waiting for stock to arrive.
But we do have https://www.overclockers.co.uk/phanteks-ph-f140sp-140mm-fan-black-white-fg-007-pt.html in stock if you wanted phanteks fans
@ChugNorris - Any chance of a deal on the Phanteks Evolv mATX case?
It was almost impossible to get anything on the Dynamic unfortunately. The PC-O11 Air at £79.99 though is a steal.
Seeing as you asked so nicely, let me know what colour and I'll see what I can do tomorrow morning![]()
Stealth dropped too!
