- 18 Nov 2018
It's scratched and I'm not gonna keep it forever. It has no value now.To be honest, I think it's better without.
Get some Googone to remove any sticky residue. Run some coloured liquid and be happy
Bit of fine polish will take those marks out easily as it’s only acrylic. Shame Gigabyte glued it in the first place.
Looks good in clear though. Especially with some coloured liquid.
Here is the picture I promised. I hope it helps. I don't know if it'll look alright with holes. Let me try to fix mine first to find a way to restore it. I still haven't run it over with the car xD
Polishing, not sanding. But yeah if you're careful you can sand then polish acrylic easy. Takes some practise.You guys really ok with sanding it? I'm scared just to the thought!
I'm not aware of other polishing methods. There is the blowtorch one too but that's much more risky.
Is this going to be mounted vertically?
How bent is the aluminium? I can't see it on my phone.
Heat it up and chuck it infront of a steamroller next time you see roadworks?
Just get a ek block. The resale value is pretty poor for cards with blocks already on. Not everyone wants to water cool a old card (old when you come to selling it) but if it had the usual fan it's worth more to someone.
