- 30 Mar 2017
There is something wrong then. What board are you using ?
Sorry, I should have said I am using adaptive mode. Dno if that makes a difference. Asus z370g
Some oc numbers, voltages, speeds and scores towards the second half of this video. Describes the chip as good silicon and it is a sample provided by gigabyte so keep that in mind.
After a lot of tinkering I have my 3200mhz ram running at 4133mhz stable on this 9900k, with cache at 5.0ghz. Needed to play with the SA and IO quite a bit, these voltages can be very picky, and less is sometimes more. On my Apex board this kit needed SA at 1.23v and IO of 1.22v, and ram voltage of 1.470v. On my Hero for the same frequency it needs SA of 1.19v and IO of 1.21v. The IMC on this chip wont run 1t without very high voltage, which is just not worth it.
Well I went ahead and ordered a Maximus XI Extreme today, I was hoping the Apex version would be available by now, but decided to get the Extreme instead. The Maximus XI Hero I have at the moment was only ever a stop gap board. Should be here Wednesday morning. Then the tinkering will begin again.
What board?
Also, use Ramtest, fella. A lot easier than running multiple instances of HCI
Apex arrived from HQ today. If you're looking to run 4133MHz+ on the DIMM side it's the board of choice besides the Gene.
Be aware that it's not possible to set the total adaptive voltage to lower than the stock VID for a given ratio (without the use of the offset function).
Where are you guys seeing the Apex ? I cant even find a listing nevermind price or availability.
Had a look at Apex at HQ a few weeks back, it is for sure on par with Gene, in fact it was marginally better on DRAM clocks and of course is full ATX which will make many happy. Absolutely the best mainboard from Asus for MAX OC potential and best motherboard full stop for overclocking I suspect.
Formula XI won me this gen, though. Fantastic looking board
Seems alright. 1.35v is high for non delid and air cooler. Either delid or drop clock/vcore. 1.35v has always been delid / water territory for the past few gen.
It does look stunning but it's not without its flaws.
The lighting is much too dim and the mirror finish on the waterblock shroud is terrible. Mine arrived with a small mark on it. I tried to wipe the mark away with a soft microfibre cloth and the surface turned black.
I can't fix the mirror finish on the heatsink shroud but i hope that i can up the brightness on the on board leds at some point. This is a common and justified complaint amongst formula xi owners.
Aside from these flaws i agree it does look great. Sadly, despite how they sound, they aren't small issues.
