Going all xdcx here but what the hell is the trash he is talking about next to it. Gravel Racing....Sounds like a poor mans CX.
It's American CXGoing all xdcx here but what the hell is the trash he is talking about next to it. Gravel Racing....Sounds like a poor mans CX.
They also do 3.4'sI'm told enve's don't build as well with 240s as they end up being less stiff. Not sure if there's any truth in that. The other issue is that 4.5s are 48 and 56mm rims, and so over the 50mm threshold I mentioned.
The Triban 500 seems to get mentioned on here a lot, with the general opinion that it's probably the best I can buy for under £500.
Yup they do that well, for me the hunger pangs tend to come an hour or 2 later unless that's coincided with a mealtime (quite regularly). Although I do find if I snack on nuts/dried fruit rather than something sugary I 'crash' less. Can even get a second wind a couple of hours later - useful if riding in the morning with a bunch of chores to do afterwards!protein drinks - fill you up nicely and (generally) taste good - it's kept me away from the biscuit jar quite nicely so far.
Extra rest day or two = feel faster = more new toys?no new toys until I feel faster.
Haha, to be fair I quite wish we had more of the trails around they seem to ride in abundance. There's parts of mid-wales where you could get away with it but much of it being forestry is private/commercial/military or a complete mud-fest from all the 4x4 nutters.Going all xdcx here but what the hell is the trash he is talking about next to it. Gravel Racing....Sounds like a poor mans CX.
Wow. Ok that's my lunchtime reading sorted for the next week xDhttps://www.hambini.com/blog/post/bicycle-wheel-aerodynamics-which-one-is-fastest/
Would be giving up a fair few watts then!
The 2019 ranges should all be released, almost all are always around Interbike/Eurobike (both back in September), but think some where released even earlier this year? Not heard of any left to come...<snip>Also this time of year is when you can pick up some bargain 2018 bikes as most brands are bringing out the 2019 ranges.
Does the Jamis fit you and how much does the seller want for it? A quick Google doesn't turn up much but one results it might be a CX bike. That should be fine at home on tarmac, you might need to put some full slick tyres on it if it has some semi-slick or knobbly CX/gravel tyres at present.
I saw a Triban RC500 in Decathlon the other week when I popped in - for ~£500 it looked pretty decent.
Are you anywhere near Merlin (Preston)? This is a 10 speed Tiagra drivetrain, so a good component spec for £525.
https://www.merlincycles.com/sensa-romagna-tiagra-road-bike-2018-106187.html
Most of us here I'm sure would recommend the Triban, the range from B'Twin have a good solid reputation - as does much of the Boardman range. You probably couldn't go wrong with any of the ones you mentioned - all quality 'known' brands, so should be no issues. There's a host of other brands with similar prices and specs of course. Obviously Halfords/Evans'/Decathlon are the way to go for most of them at this price point but hunt down vouchers, deals and maybe even a cycle2work scheme to make things even more affordable. If one is available through your employer you could pickup a bike in the 700-800 range and the vast majority of the accessories you needed within the grand total - helmet, lock, shoes, GPS etc which would work out well with your initial 'budget' covering half of it (but spread over a year, so easier to stomach the cost).
Regarding the type of riding you mention - general road riding, distance and possible rough surfaces (think the Trans Pennine is scetchy in places - think canal towpaths), then a relaxed fit 'endurance' bike, possibly a Gravel type of bike would suit you best. Maybe even a CX bike (like the Jamis!). Of course the type of riding you do (and end up enjoying) isn't known yet!![]()
The Triban bikes are really good value for money and always get decent reviews. They'd probably be my choice unless you're confident enough to go second hand. Or does your employer offer a Cycle2Work scheme? Could use that to get a nicer bike in your budget. Also this time of year is when you can pick up some bargain 2018 bikes as most brands are bringing out the 2019 ranges.
For a Pinerallo though, not sure what's up with that steerer/fork...
That Hambini aero test has been causing controversy and chaos on Weight Weenies, Slow twitch and Bike Radar.
Howcome?
I am liking that a FFWD F6R is as aero as a Zipp 808.
https://www.hambini.com/blog/post/aero-bike-wheel-test...-the-fallout/That Hambini aero test has been causing controversy and chaos on Weight Weenies, Slow twitch and Bike Radar.
The ultimate result was I ended up getting banned from weightweenies for a week for calling Tom Anhalt of bike blather a spec of ***** on the anus of humanity and a letter went from Flo Cycling to my HR department to ask for me to get the sack.
Damn, fairly sure they can be changed straight forward enough. Remember seeing a 'tear down' of someone changing a battery on an 800 and I'm sure I looked at my 810 and although I didn't take it apart it looked straight forward enough. Worn puck/mount? Have to say my ELEMNT has started to work slightly loose in my K-EDGE. I think it's just a bit of grit/muck gets in there and adds additional friction between the plastics. Has just lead to a slight rattle on really bumpy ground. I bought the puck as an insert (£8?) but probably need to check it on the original Wahoo outfront to confirm it's the puck that's worn and not the mount on the unit. Rambling. Sorry. Basically - Mantel sell pucks/inserts for various mounts if that's whats worn on yours.Yay, smashed my Garmin 1000 last night after it jumped out of my mount and into the road, going to attempt to repair it with a new screen!
But on the plus side Canyon have finally agreed to replace my handlebars under warranty. Guy on the phone said, well it looks like they've had an impact but I can't see any evidence of it so I couldn't really deny the claim. Well that is because there was no impact!
EDIT: Is it me, but much of the posts on his blog are intended to shock consumers?
Prime example: https://www.hambini.com/blog/post/ceramic-bearings-vs-steel-bearings...-an-engineering-opinion/
TLDR; Ceramic bearings are far less smooth (giving far larger losses) than a premium steel bearing once ridden over 1000km, the further you go the worse they get!![]()
