Corsair PCIe cables
9 Nov 2005
manchester,uk
Corsair do list individual pcie cables on their website so as pasty mentions I would try asking them, or see if one of the Corsair reps on here can help @Corsair Nick
Other option is to go over to Linus forum and ask Jonnyguru as he is an active poster on there.
The post below for example is regarding the 750W CS unit. Not sure if the 650W is the same platform/pinout etc so best to double check.
https://linustechtips.com/main/topic/940110-corsair-cs-750m-pci-e-8-pin-oem/
11 Dec 2006
We have replacement cables available on our webstore for purchase. The one you will need is through the following link. We also offer worldwide shipping for most regions as well.
https://www.corsair.com/us/en/Categ...ible-with-all-type-3-pin-out-PSU/p/CP-8920129
Let me know if you have any other questions.
It's great you sell cables but is there an easy way of finding out which type fits which PSU? I used a new AX760 I had as a spare for a couple of years in a new PC build recently and wanted extra cables and the Corsair guide here isn't clear between type 3 and 4 in some instances.
In the end the cables I got had one wire in a different location leaving another empty (the reverse of the original). Although I believe from research both those pins are the same voltage on the PSU I decided not chance it and switched them with a connector remove tool to be sure.
