- 14 Apr 2014
- Hampshire
It entirely depends on what the issue is.
Was thinking likely DMF
Edit - clutch itself was replaced I believe 10K miles ago
And the exact car. Vibration can be when the spring on the DMF goes, or it can be a lot of other things as well. Need to find the route cause first.Was thinking likely DMF
Will look into it a little more - thought I'd bring it up as I came across this thread![]()
It certainly could be - weren't you advised to replace the DMF when the clutch was replaced?
A couple of months old and on its second owner, second clutch, and with over 10,000 miles on the clock?
That wont be the case at all, no such thing as a VW Clutch or DMF. I would bet its an LUK item or a Sachs, in which case you need to find the LUK/Sachs part number.
Edit:
I might be wrong but whats this, ive only had a very quick look.
https://www.onlinecarparts.co.uk/luk-970948.html
£282
