- 18 May 2010
- London
The main take away is it's crap you are tied to a vendor(regardless who's to blame) but both can run AS panels if you want to.
Nope, AMD do a higher max fps range than G-Sync panels, and your mates G-Sync's far from Ronseal when it's throwing up artifacts due to a panel/G-Sync bug.![]()
That's an Acer issue tho. Not necessarily Gsync or Nvidia.
But then not all panels do it. We've already established that with FreeSync it's hard to work out what the synch range is for the panel in question.
