I would like a smaller LIGHTER case...
8 Jun 2005
9 Jan 2016
Derbyshire
Something like:
My basket at Overclockers UK:
Total: £98.09 (includes shipping: £11.10)
Or the RioToro 1080 are probably about as small as you can get for a Full ATX motherboard:
https://www.riotoro.com/cr-1080
wow i did not expect to see atx cases of that size in a tower like form, that linked one is certainly nice
350*188*380mm this is my case size and m-atx, so these 2 cases are impressive..
Hi all,
I have the following:
https://www.overclockers.co.uk/detail/index/sArticle/67698
With a 1080ti
In this case:
http://nanoxia-world.com/en/product...1-rev.-b/206/deep-silence-1-rev.-b-dark-black
The case is good... and quiet... but huge and VERY heavy.
It's a pain to lug about to LANs etc.
Does anyone know what is the smallest case I can cram all of this into without having terrible airflow?
I'm massively out of date.
Cheers,
Alex
just another thought on the subject, i dont know how your Lan parties etc go and how much demand you need, but have you thought of maybe making a smaller form factor computer to use just for such events?
1 Apr 2014
Aberdeen
How much are you willing to spend? Are you willing to get an ITX motherboard? Are you willing to drop overclocking?
At one point many years ago I too got fed up with lugging a huge PC around so got myself a Shuttle XPC. These days I'd get myself a Dan A4 or Bitfenix Prodigy ITX depending upon budget. I haven't been to a LAN do in nearly a decade, though.
Total: £296.68 (includes shipping: £11.70)
The Bitfenix case has the advantage of handles which make it easier to move; the Dan A4 is, of course, incredibly small.
You might be better off buying a small suitcase and lining it with foam. Then, when you want to go to a LAN meet you put the PC in the suitcase and carry it that way.
OP
8 Jun 2005
I built a little trolley for the case so I can drag it about lol
But I have arthritis and my wrists are sore so I'd like something lighter.
I'd be up for changing motherboard and dropping overclocking if I could still fit my 1080ti in there :) But I'd have no idea what mobo to get.
15 Jun 2009
I realise this is originally a 2 month old thread but thought I'd add this.
I wouldn't be comfortable using them as actual handles if you've got anything semi heavy in there as they don't really have any actual strength in them.
OP
8 Jun 2005
Something like:
I really like both of those!
I don’t like the fact that you can see through both sides of the Thetis because you’ll see all the wires. The other problem I have is I use a 240mm rad and I’m not sure it will fit in either with an ATX board.
OP
8 Jun 2005
Honestly.... that's not to my tastes at all... I want something sleek and clean looking tbh
Thanks for the suggestion tho :)
11 Mar 2013
I want to go small as well. I'm thinking about going itx SFF. I don't need a huge case anymore. A smaller footprint would be better for me.
I'm liking the Raijintek Ophion Evo. Don't know what the noise would be like in that case?
23 Jan 2019
Just get the Thermaltake core v21 without a second thought if your goal is to move your pc here and there - Its great, has a very small footprint and has excellent space for all of your high end hardware needs, airflow is also great if you toss in a 200m good quality fan. STILL if it doesn't ring your bells then explore more or check here - https://appuals.com/best-micro-atx-cases-for-custom-pc-builds/ this is the only comparison I could find that is latest and has the best options for 2019 march.
1 Dec 2015
282mm card and 140mm PSU
more expensive but just as small - aluminium and glass as well
