Permabanned
- 12 Sep 2013
- Knowhere
it was a goal of freesync 2 and to my knowledge they have achieved a range of a min of 48-144hz i havnt seen a single panel with a smaller range like freesync 1. also "The end result is LFC effectively removes the minimum refresh rate of adaptive sync displays, but for LFC to be supported, the monitor needs to have a maximum refresh rate that is at least double the minimum refresh rate. This is why not all FreeSync monitors support LFC; some come with just 48 to 75 Hz refresh windows, which doesn’t meet the criteria for LFC. However in the case of FreeSync 2, every monitor validated for this spec will support LFC so you won’t have to worry about the minimum refresh rate of the monitor."
so freesync 2 supporting lfc means that all monitors must have a bigger range.
melmac is off on the range part slightly.![]()
You're right, they announced the inclusion of HDR from the get go, it was a point of discussion at the time. As for LFC that's what it should have been about, my monitor has a range of 30 to 75 with LFC support & it works, The next iteration of Freesync should have only been about LFC & the range required to support it, AMD leaving Freesync still covering anything without HDR is allowing a question mark to hang over all other Freesync models, They haven't remedied the base problem of Freesync being seen as the inferior solution and that is what should have been bothering them, they'd said as much in past interviews.
