- 28 Nov 2018
- Monstrocity
Chequers, anyone? Chess...?
EDIT: Oooh, pretzels!
I think ill give it a couple of days before i install these.
Love those pretzels!
After applying the GPU overclock option instead my PC crashed, this is hilarious.
I want to point out that using the Auto-OC feature on Vega will most likely result in a crash but it is somewhat expected as it tries to find the threshold for your card, in fact, the warning message will notify you of that to an extent.
AMD rep @ reddit..
i would just benchmarked assassins creed odyssey and im down 20 fps on that as well
and now ive just had a pop up saying default radeon wattman settings have been applied due to system failure even though i have never seen or been in wattman
AMD rep @ reddit..
Ok, so does wattman log the last stable frequency before the crash and use that the next time or is it completely useless?![]()
To me, it seems backwards. It seemed to just massively ramp my GPU clock up instantly and crashed the driver.
To my mind it should slowly keep increasing until it hits an issue and then set it to just below that.
The fan speeds I'm seeing are not what is set in Afterburner or Wattman so I'm rather confused. Changing settings in either application seems to do nothing.For those having problems try removing,
all third party monitoring programs and overclocking programs,
i.e. Afterburner, trixx, etc, before you DDU And install the new drivers.
Then try out the new features of the driver.
