Shortly after receiving a new VEGA 56, I decided to return it for a refund (I didn’t feel there was anything wrong with the card, but I found it frustrating that it was causing the screen to flick on and off, apparently it needed to be undervolted which partially helped the situation)
Today I received an email saying that the card has a damaged 8 pin connector and is being returned to me, OCUK wont issue the refund as the card is damaged and I didn’t notify them of it. When I first got the card, I noticed the 8-pin connector was a bit wonky but figured if it worked then I wouldn’t worry about it.
I personally the amount of damage to the card (which wasn’t even done by me) is minor, I have spoken to OCUK about this, but they just said I should have notified them of the damage, now I’m stuck with a £350 card, that I don’t want, and potentially shouldn’t even use. I used to rate OCUKs customer support as the best for PC eCommerce, but this feels very unfair.
Not sure if this is the right forum, for the thread, or if it will even survive…
