Intels 28 core
And how much will a supporting motherboard cost? Presumably none of the existing boards have the VRM's to support such a chip?
can't speak to the prices, but it will be on a new socket (or at least new in the consumer space) LGA 3647 and 6 channel memory so will be all new motherboards for it.
This one: https://www.asus.com/Motherboards/ROG-Dominus-Extreme/
And I reckon it'll be about a grand on its own.
Dual 24 pin, quad 8pin and dual 6pin 12v for “industry leading power efficiency”...
I assume there is a footnote missing stating that dedicated feed direct from the power station is optional..
I also love that the cpu alone will cost more than the majority of a system built around a TR 2990WX..
:D I had to to have a little chuckle to myself as well when i read that. So at least 2 1Kw power supplies, plus of course loads of LN2 to get it to that "ability to overclock to 5Ghz". Yes Intel, we can all see how much of an "industry leading power efficiency" edge you have over the opposition :D
Of course we won't take into account the cost to the industry of the LN2 8pack will need to use to get there.
To my calculations which include the CPU for 4 grand, mobo for 1 grand, 1 kit of 6-channel DDR4 for 1 grand, industrial chiller for 1-2 grand and a PSU for 0.5 grand, that is a pretty respectable amount ~8 grand :o
Oh, and a 2080 Ti for 1.5 grand.
So, in total ~10 grand more or less :D
Where do you get the 2x 1Kw figure from?
I'm not disputing it, i'm searching for info.
"Dual 24 pin, quad 8pin and dual 6pin 12v"
Screams 2 PSU's to me, and i can't see anyone using less than the best PSU's they can find.
