Caporegime
- 7 Apr 2008
- Lorville - Hurston
Anyone use Gimbals here?
I currently use a zyhiun crane plus which is a bit light weight but not the easiest to setup on the field for run and gun video work unless you preset and note down the axes settings you use for a particular camera and lens setup.
What i dont like about it is that it blocks the LCD screen a bit but overal it does the job on my sony a7r3 and a small prime.
At a push i can use my 35mm sigma art prime at its absolute but no longer lenses then that due to the bit that blocks the back of the camera and weight.
they are about to release this one though which looks smaller!
https://www.youtube.com/watch?v=43JvTlQRwc8
