New build sense check
I'm going to spend the next few days mulling this over. The build will probably done in January anyway so maybe worth hanging out a few days to see if any festive offers appear from OKUK.
if you're going to wait that long, might as well wait a wee bit longer - apparently amd are going to announce their ryzen 3xxx series cpus in january (soon *tm)
Hi guys, I thought I would join this conversation so not to start a new thread, just quick question, at the moment my system is :
Asus P8P67 Deluxe
Intel I5-2500K @ 4,5Ghz
Gigabyte GTX 970
G Skill Ripjaws 8GB dual channel kit (1600Mhz)
Power Supply : Corsair TX650
I thought its time to upgrade my system, and I was planing to buy :
I9-9900K
Asus Rog Strix Z390-E
Corsair Vengeance LPX Black 16 GB (3200Mhz )dual channel kit
My question is the RAM fits for this build or is there a better choice ? Do I need a better power supply or mine is enough ? I checked with cooler master psu calculator and filled all the fields and it says 545 W it what going to use
Asus P8P67 Deluxe
Gigabyte GTX 970
I9-9900K
Z390 Aorus boards or MSI. Better VRMs set up.
Plan to push 5ghz plus and do workloads then Aorus boards .
If your gaming, 9700k 8 core non HT will be just fine, HT adds about 15% performance on top
oh lord don't say that!!
X570 is Q2 2019 . Roughly a year between each ryzen .
Haven't seen any roadmaps with boards releasing earlier . Haven't seen engineering sample yet , normally would have been good leaks by now .
start a new thread, so we can give you answers for your need.
this is skalaberg's thread after all...
