Permabanned
- 8 Feb 2004
Tap dispensed carbonated drinks all have a tendency to foam which is a big problem to maintain carbobation for extended periods. Sugar content influences both viscosity and surface tension which will hence influence the foaming at the point of dispensing and the how it can be controlled via nozzle design. Basically it is a formulation problem working against physics but it's not like coke can change the recipe is it?
