Also if they announced pci e
IMO real world performance of this in some titles will match or exceed the 2080Ti / Titan. Namely ones which either do or can lean very heavily on compute based rendering.
Vega 64 is pretty much neck and neck with a 2080 in PubG & Blackout once you fix the voltages, which both do the above. Also doubt it'll be behind in iDTech.
Also, remember that is the tangent NVIDIA sponsored games are taking now, since the 20xx series cards finally caught up with AMD on compute based rendering, and left their own old cards in the dust.
If some samples can really OC from stock 1.8Ghz to 2.4Ghz, there's going to be a huge secondary market for high clocking samples. Performance ought to be higher than anything else out there.
Let's hope they have serious volume ... though I fear, again, HBM2 / interposers will limit supply. If they do, then NVIDIA have no choice but to make large price cuts.
Unfortunately in the real world it does not work like that.
The Titan V for compute work is a very long way ahead of any other gaming card but this does not help it very much for the situation you describe above.
I was hoping given the clock speeds aren't that much higher, as well as the lower number of compute units, we'd see less power draw on 7nm
