- 11 Jan 2019
Hi,
Thank you for reading my message. A friend of mine recommended I post an issue I’m experiencing with the Oculus Rift with my ASUS laptop on this forum.
THE STORY:
I've purchased an Oculus Rift 09/01/2019 from Argos to run on my 7 week old ASUS FX504 EN150T laptop bought from AO. The laptop is sold as “VR Ready”.
https://ao.com/product/fx504gmen150t-asus-laptop-black-59693-251.aspx
Dedicated GeForce® GTX 1060 6GB graphics - VR ready
8th gen Intel® Core™ i7-8750H hexa core processor
8GB of DDR4 RAM delivers seamless multitasking
1TB hard drive with a 256GB SSD
Laptop on Overclockers website:
https://www.overclockers.co.uk/asus...7-8750h-8gb-ddr4-gaming-laptop-lt-25n-as.html
On the laptop I have 3 USB ports on this laptop, 2x USB 3.0 and 1x USB 2.0.
I have plugged the 2 sensors into the USB 3.0 and the headset into the USB 2.0 and HDMI
I have also tired using a USB 3.0 docking station where I have connected all sensors and the headset to USB 3.0, but as I’m experiencing identical issues further testing will be using the laptop USB ports only.
THE PROBLEM:
The sensor setup (guardian) works perfectly fine setting up the gaming boundary. The problems starts when I first enter the game menu. Initially I can see the touch controllers (my hands) and can move my head around without lagging, but within 30 seconds the picture starts to jerk and jump. I sometimes hear the windows sound for a device being plugged in. I sometimes receive a warning regarding the sensors. I’ve also seen 1 time a USB malfunction in windows.
If I exit the Oculus app or go through the sensor setup again all is fine, but I often have to restart the laptop, as the sound sometimes disappears on the Oculs headset. I've also had it where the sensors are no longer detectable and a restart of the laptop is needed. I've also had the laptop crash on me once (blue screen), which is something I've never seen since I bought the laptop on 23rd November 2018.
I would like to know what I need to do in order to get the Oculus working and stable. I've tried getting into a game quickly ”Robo Recall” and that also starts jumping and the game eventually crashes with me losing the sound every time (requiring a laptop restart). Menu or game the jerking / jumping is awful with the Oculus is unusable.
I would have to say the laptop has been stable since I purchased it and I've not had any issues with it until trying to use the Oculus, but I cannot rule out the issue with the laptop itself.
Installed on the laptop I have Microsoft Office 2010, Fusion 360 (CAD Software) and McAfee Total Protection (which I have switched off during testing).
Please can I ask that you supply me with a list of things I can do to diagnose the problems or adjust on the laptop, so I can have the Oculus running without fault?
I
have also sent the above to ASUS Support & Oculus Support and await a response.
Kindest regards,
James
THE STORY:
THE PROBLEM:
I
Kindest regards,
James
It looks like there is only one controller. How many 3.1 ports are on the laptop?
