Speccing a system for Autodesk Maya 2018 – advice please!
3 Jan 2019
Hi all,
I’ve been dabbling in the the word of Autodesk Maya 2018 for the past few months. I’m still very new and loving it, but the biggest stumbling block is my MacBook Pro 2015 – it’s just not capable enough. I realise that if I want to advance it’s best to go down the PC route.
So, I’ve spent some time researching and have come up with a first draft spec. I’m looking to spend around £1,500 (not including monitor, keyboard and mouse). I’m new to speccing systems so I’d really appreciate some thoughts, advice and guidance from this wonderful community.
Here we go…
Processor: I want something to cover modelling/animation and rendering as I’m too new to know what I’ll end up doing more of, but so far I seem to be doing more rendering. Rendering is better with multi-thread, so more cores. Modelling/animation is better with single thread, so higher clock speeds (you probably all know this!). The chip shown below would be right for rendering, but would it be the best option to cover all bases?
https://www.overclockers.co.uk/inte...e-socket-lga1151-processor-oem-cp-65k-in.html = £479.99
Graphics: Maya recommend Nvidia over AMD. The Quadro range are preferred, and this one is high on the Maya preferred list (I believe the Quadro range is mostly for rendering).
https://www.overclockers.co.uk/pny-...-card-5gb-gddr5-1024-cuda-core-gx-05n-pn.html = £480.98
Or, is the newer GeForce RTX the way to go? Like this one for almost the same price as the Quadro?
https://www.overclockers.co.uk/giga...92mb-pci-express-graphics-card-gx-1a4-gi.html = £488.99
I really can’t tell the difference between motherboards! But not all motherboards support i9 chips. If I go i9, then this one seems right, however I’m open to suggestions – could I go cheaper here?:
https://www.overclockers.co.uk/msi-...cket-1151-ddr4-atx-motherboard-mb-342-ms.html = £169.99
Memory: 16GB is fine for Maya, 32GB is the dream for rendering – but is expensive. Is 3200 ok, or can I feasibly go lower to save money and maybe get 32GB? Minimal noticeable difference between the speeds?
https://www.overclockers.co.uk/team-group-vulcan-t-force-16gb-2x8gb-ddr4-pc4-25600c16-3200mhz-dual-channel-kit-black-grey-tlgd-my-09s-tg.html = £119.99
HDD: I can add more drives to the case as and when needed. Will probably need 2 drives eventually, one for OS etc, then a big fat HDD that can be used as a scratch-disk for temporary files etc. Any thoughts on this?
https://www.overclockers.co.uk/seag...a-solid-state-drive-stgs500401-hd-3a8-se.html = £69.95
Power Supply: 500W should be ample, right? I specced a modular one as I’m a neat freak and hate cable clutter! I could save money here I feel. Advice welcomed!
https://www.overclockers.co.uk/be-q...plus-gold-modular-power-supply-ca-131-bq.html = £72.95
Case: As small as possible and quiet if I can! Not after lit fans etc.
https://www.overclockers.co.uk/cors...dition-mid-tower-pc-case-black-ca-196-cs.html = £57.99
And Windows 10, obviously:
https://www.overclockers.co.uk/microsoft-windows-10-64-bit-dvd-oem-ms-kw9-00139-sw-172-ms.html = £109.99
TOTAL (with the Geforce RTX): £1569.84
That’s it! Is there anywhere I can save money, or anywhere I’ve over-specced unnecessarily?
Thanks in advance!
Edit to the above post;
After more research I'm inclined towards the RTX 2070 as I think the RTX would create a more versatile machine. Plus Arnold renderer is CPU-based, not GPU so the Quadro wouldn't impact this. Would anyone have any thoughts on this? Advice appreciated as I'm new to speccing PCs!
I see a lot of recommendation for buying a used GTX 1080ti over an RTX 2070, but reading about it has got me a little confused! Anyone have any thoughts on buying second-hand cards?
I'm also now thinking about getting a 250GB nvme card for the OS etc due to sheer speed, and a large HDD for storage. Is this a good way to go?
Still not sure about which motherboard to get – I've read so much but it does result in more questions than solutions! I'd be looking around the £160 mark.
Sorry for so many questions. I'm appreciative of any advice and help.
Thanks!
You may find a Ryzen / Threadripper build better for Maya. AMD are rumoured to be announcing new chips at CES next week.
Thanks for your thoughts Quartz.
I hadn't considered AMD chips for Maya. Were you looking at it from a final rendering point-of-view, where the multithreading is more beneficial? When the new chips are released, would that see a reduction in prices of ones such as the Threadripper 1920 or 1950x?
Thank you both, good to know.
Any thoughts on the GPU I've specced? Is it overkill considering rendering uses CPU rather than GPU? Or should I go for it considering I have the budget? If I went down the AMD route, is it better to go with an AMD card?
Hi Adam182. Absolutely! :) I keep changing my mind but am getting more settled on my spec.
Quartz suggested the AMD TR CPU which looks great, but I’ve thought more about how I use Maya and animation is looking as likely as rendering. After much reading, I think the i9 would cover both bases better. Either way, it’s in my budget and it’s a good chip. What are your thoughts?
I’m struggling with the motherboard at the moment. Any recommendations? I was looking at the Gigabyte Z390 Aorus Pro which gets pretty good reviews. What do you think of that one? It’s in the price range I was looking at.
I’m also looking at the Corsair TX650M. Again, it’s the right price and is reviewed well. Open to suggestions though.
To sum up, the possible build would be:
Intel Core i9 9900k
Gigabyte RTX 2070 Windforce
Corsair Vengeance 16GB 3200
https://www.overclockers.co.uk/cors...hannel-kit-black-cmk16gx4m2b32-my-456-cs.html
Gigabyte Aorus Pro Z390
https://www.overclockers.co.uk/giga...cket-1151-ddr4-atx-motherboard-mb-579-gi.html
Corsair TX650M PSU
https://www.overclockers.co.uk/cors...lar-power-supply-cp-9020132-uk-ca-234-cs.html
Still not sure about which nvme m.2 SSD to get for the OS/software etc - they’re really pricey. Would I see the speed benefit or is there a more cost effective option that’s good? I’m going to get a 1tb or 2tb 7,200 HDD for storage though.
And then there’s the subject of cooling...from reading up about it, a cooling kit seems like a must-have. Is this the case?
Thanks so much for everyone’s input so far, massively appreciated!
Thanks lee32uk, these are useful. Helpful in confirming what I've specced so far!
I'm thinking of the 860 Evo 500GB SSD, and ditching the 1TB for now. Looks like I'm nearly ready to buy!
I can confirm you are on the right track spec wise.
I'm a full time animator myself and use Maya/Max/AE and am also currently in the market for an upgrade.
As I arnt willing to wait for the new zen chips I'll be opting for the 9900k as well.
The rig you specified above will be great for any 3D package you throw at it.
ref RTX 2070 r u sure the software will make use of the card - you might be better off purchasing a (technically) lower spec quadro or AMD version...
you would need to find some benchies to compare... might be gaming card is fine might be its garbidge
Thanks so much for your thoughts, Adam182. So good to hear – this gives me real confidence to go ahead!
Good point edscdk, I've looked at the benchmarks and the RTX2070 should be fine. It's in my budget too so I think I'll go for it.
Hi orbitalwalsh! Eisbaer 360 water cooler, right? Looks terrifying! :D I might go for the Dark Rock Pro 4...I think I could handle that one!
Once again, thanks for the help everyone! You've all been amazing.
Ok, one last question (maybe!) if I may...
I was originally going for the Gigabyte RTX 2070 Windforce:
Then orbitalwalsh recommended the Gigabyte GeForce RTX 2070 GAMING OC card:
https://www.overclockers.co.uk/giga...92mb-pci-express-graphics-card-gx-1a5-gi.html
The Gaming OC is £70 more than the Windforce. Is it worth spending the extra for the boost? I can't seem to find any head-to-head reviews.
Thanks!
You really wont notice the difference either way, would be much better spent on upgrading a peripheral or a larger ssd etc but if its just £70 kicking around go for it :)
