Don
- 20 Oct 2002
- Oxfordshire / Bucks
Is it at all possible to check the level of charge the battery is getting when the car is running from the 12V socket inside the car ? (or obd port))
for example, im driving to and from home directly so the mileage is low, is it possible to check what the cars battery level is ?
I've put a volt reading checker into the cig lighter and i can see that when the car is running the voltage is higher than when the engine is off (because its charging) but what level is the battery at i'd like to know
i.e. 80% charged?
90% charged ?
is there a tool or lead that will do this?
i.e. 80% charged?
90% charged ?
