Could this be repaired? (Windscreen)
Man of Honour
24 Sep 2005
Hello! I don’t frequent this place often and I don’t know much about cars so please be patient / kind! :)
My car was damaged on a motorway by a rogue stone - very annoying. Here’s a photo of the ‘chip / crack’. The raindrops should be a good indicator of size. Previously when I’ve had chips I’ve arranged for a man to come out and sort it with a.... device that fixes chips miraculously. This time, I don’t think I’m so lucky and I’m rather dreading having to replace the whole windscreen. The cracks seem deeper than surface level.
What say you, motor gods?
Where is that, that may be key for this one, it looks dubious as to whether it would get through MOT if in the drivers eyeline
Its probably repairable if not in eyeline
Thanks for your kind response! It’s in the passanger seat’s “eye line” away from the driver’s side and doesn’t affect the driver’s view of the road.
I think they usually only repair them if the crack is less than the size of a £2 coin. Your impact point looks pretty small but what’s the deal with that semi circle around it? Is that a scratch or a crack on one of the internal layers?
Thanks all.
That small circle was from the impact of the stone. IIRC it is surface level but not being next to my car it’s hard to say.
Sounds like the plan is to try and arrange a repair ASAP before it gets any worse.
Such misfortune, oh well.
The star burst part can be repaired but the circular crack around it doesn't look repairable as the epoxy cant get into it.
Had one many years ago and this time of the year and the heat from the heater on the screen made it expand half way across the screen so be careful until it is sorted.
Your insurance probably has free repairs for chip repairs (mine does at least and wont effect your no claims), so worth calling them.
Alternatively the Rain X Epoxy kits have worked well for me in the past they only cost about 6 quid.
Can you feel the circular bit? Or is it between layers of glass?
i'd rather have a new windscreen than one with a repaired crack in it. excess is like £50 these days. and it doesn't count as a claim on insurance either. cracks aren't pretty to look at.
OP, how did you get on?
Had a stone hit my screen yesterday in the "A" zone and it is less than 1cm across except for one crack coming off it that just exceeds the limit. So no repair possible and £75 excess for a new screen.
What car?
Audi A1
It’s actually my partner’s car - she’s reviewing options at the moment. Thanks for the comparative info!
