- 29 Feb 2012
- London
The FTW3 is even better to look at when you see it up close and running.
Don't forget to download EVGA Precision X1.![]()
Thanks buddy
3 hours of FC5 last night, max temp of 64C and fan 1800rpm. Surprisingly quiet TBH.
Well looks like im going to have to return this EVGA Black edition card. Will not no matter what flash with another bios so i am limited to 112% or 280w maximum. Which limits the card heavily in terms of overclockability on core and memory. 1850mhz ish and it’s struggling.
Something to do with nvidia selling non binned chips which are slightly different A chips so essentially you cant overclock it, put different bios etc as it registers as a gpu mismatch. My old FE had a 380w bios on.
Looking at stock levels and pricing and such I’ve just gone and ordered another 2080Ti FE and will return this at some point next week.
@Kaapstad may as well remove me from the list as the card will be going back shortly.
Luckily i haven't started stripping it down yet D:
Ah sorry to hear that m8, didn’t put the block on? I’ve just sent you an email!
If it’s a ref board you can overwrite the mismatch with NVFlash64 just fine. Use the -6 switch when flashing it.
Worked for my Zotac AMP just fine. Reverted back to stock after playing around with it for weeks but I was curious about the cards limits.
Just says "command format not recognised" with -5 -6
same with -4 -5 -6 :/
See the post 3 above this one. I’d give up and just send it back.
Ahh just seen it. I had no trouble flashing my old FE with the -6 command.
Never even thought they were doing dodgy chips or i wouldnt have bought it. Just guessed it was an inferior cooler and boost clocks to the XC line up hense the lower price as the card is for water so the cooler was a non issue.
Will get an XC instead for the price difference.
Wouldn’t call them dodgy, just lesser binned chips. Guess it’s how they sell them for less but they’re certainly not cheap.
Cheapest XC card is an A chip, should be fine for BIOS flashing.
Had my Zotac up from 260W to 360W+ and it clocked great but I couldn’t face the increased fan noise. Shouldn’t be a problem with you watercooling though.
Now back running stock BIOS and everything I throw at it still flies along at higher FPS than I need as I’m only after 4K/60.
Overpriced cards but nothing else realistically competes IMO. Glad I got mine even though it pained me to spend so much on one.
I reckon 800 quid for sh 2080ti by the end of the yearSo how much value will a 2080ti hold by the end of the year?![]()
