- 25 Nov 2005
If time travel were possible and time is relative
If you went back in time do you go back in time to the spot where you were in the future when you started to go back in time
Or do you go to a new spot relative to the Earths spin in reverse by however many years you have gone back ?
Would the same apply to any point in space or only objects influenced by mavity ?
For instance if I went half way between the Earth and Moon and went back in time 1billion years, I could still be in the same point in space but the Earth and Moon will be in a different location to where it was before I went back in time because of their orbits around the sun and the solar systems orbit around the galaxy
Or would I always be half way between the Earth and Moon ?
What happens if you go back before the Earth or Solar system even existed ?
I think logically your point in space would stay in the same, but everything else would be at a completely different point in space depending on rate of orbit/spin, if you could reference your point in space
