- 3 Oct 2009
- Wales
I'd be interested to know what ways around it you think there are because as far as I'm concerned it's cut and dry.Yes, I've noticed that. There are some ways 'around' it.
As a first time buyer you're unlikely to be buying a house with enough contents that it makes a significant difference to the price by doing that. Plus it would mean needing a larger deposit as you'd be paying for the contents from your own cash. So pretty much irrelevant in the circumstances.Sometimes you can negotiate to pay for the white goods/furnishings seperately.
So you'd do the 250k mortgage, then pay a lump some of 7k for example if the house was sold for 257k, that way you'd still get the gov bonus. This obviously depends on who you have the mortgage with...also probably not always likely to happen .
If you have debts pay off in this priority order ASAP
Credit Cards
Loans
Student Loans
Obviously getting a mortgage while you have debt is harder but some debts are riskier then others especially when the application gets put through stress testing.
For your wife, 2-3 years books or self assessment tax returns. Its daunting when one or both of you is self employed but don't let it be, as along as your have your paperwork in order it makes things easier.
Using a mortgage broker can smooth out the process.
Look in to the help to buy schemes, lots of new builds around, some stock being hard to shift, you might benefit from Brexit and a slowdown in the market with New Build Developers struggling to shift stock.
Happy to chat any time.
Just some thoughts from reading all the replies. You've mentioned your combined earnings are about 42k (30/12), sticking these into a mortgage calculator gives you a figure of around 200k.
Minimum deposit is 5%, and as you seem to already be aware, the bigger your deposit the lower the LTV and the lesser the monthly payments are.
On a 200k property with a 10k deposit (5%) would require a mortgage of 190k and give you monthly payments of around £800-880/mth (based on a 30 yr term)
On a 200k property with a 20k deposit (10%) would require a mortgage of 180k and give you monthly payments of around £720-760/mth (based on a 30 yr term)
On a 200k property with a 40k deposit (20%) would require a mortgage of 160k and give you monthly payments of around £580-600/mth (based on a 30 yr term)
The above gives you an example of monthly payments based on the different LTV rates.
Have you had a look around the areas you wish to buy to see what you can afford? This will at least give you an idea of how much of a deposit you need to save.
As for saving for the deposit, you mentioned a HTB ISA, but with 1k in it? is this actually the HTB ISA, or a HTB LISA? It sounds more like the latter? The HTB ISA which was available 2 and a bit years ago allowed you to open the account with a 1k deposit to gain a £250 bonus.
Anyway from what i've read, you mentioned your current deposit savings are practically zero. You mentioned you and your wife also have some debt - Credit card for you, and overdraft for your wife? (When does your wifes free overdraft end? iirc from graduate accounts you normally get a year or 2 before they start applying interest). Either way a mortgage advisor/broker would tell you to clear those debts, as they will eat away at the total a lender will give you - there's a section called monthly commitments and this will include anything like student loan repayments, and any credit commitments, and this can reduce things quite drastically.
I had the mishap last year of running into this, i purchased my missus engagement ring on credit (i had the money in my account to pay instantly, but wanted the credit card protection). Anyway shortly after we found a house we liked and went through the process of putting in a bid, went to get an AIP, and the total amount they'd lend us came out something ridiculous like 30k under what it was with 0 debt. (the ring wasn't 30k!). Thankfully they hadn't yet taken payment of the ring, so i was able to change the payment and clear the debt from my account.
Without rambling on too much, based on the details you've given so far, unless you've got a family member gifting you a substantial deposit (10k+), then i suspect you'll be spending at least the next 12 months clearing your existing debts, and putting savings aside for a deposit. Personally i think you'd be better switching to a HTB LISA (1k bonus for every 4k saved), so have a read up on those and see if it makes more sense switching. Someone earlier mentioned about the Governments HTB schemes, i think this works by you providing some money as a deposit, and then the government also providing some money as a deposit (as a loan) - say 10k/10k each. The loan value increases/decreases depending on whether the value of the house increases/decreases. So if it increases 10% then you'd now owe 11k on the deposit loan. From memory these are typically 5 year loans as well, so you'd need to ensure you can not only pay your monthly payments, but also save up enough to pay off the governments loan at the end. There was a thread on here a couple of months back with someone in this sort of situation where he'd been paying back the monthly mortgage amount, but wasn't putting enough aside to pay back the loan at the end. I think these schemes can be a little irresponsible as it can open doors to houses (no pun intended) for people that wouldn't necessarily be able to afford it under normal circumstances.
Final point, i think someone's already linked you to the mortgage guide that Martin Lewis has published, that covers pretty much everything you need to know about mortgages.
what is wrong with new builds? they usually come with the latest and greatest of everything. the only issue i can see is if you can't afford a decent one so you end up with a crap one. or the relatively small gardens and driveways but that isn't a huge deal tbh.
wiring will be up to the latest standard. insulation up to the latest standard. boiler and everything else will be latest and energy efficient, etc. same with a lot of the appliances (dishwasher, oven, etc).
my advice to OP is nationwide are a really good lender that also offers cashback, etc at times.
also you need to find out your LTV and if it's close to a band then increase it to meet the next band. e.g. on a 200K house lets say you have a 19K deposit. which is 1K less than 10% so you fall into the 5% LTV bracket which isn't that good. by having that extra £1K you would fall into the 10% bracket and have a much better interest rate as a result. so you need to do your own figures and see what works for you. it's always best to have a multiple of 5% as your deposit. so 5%, 10%, 15% 20%, 25%, etc. if you have 13% then try and get that extra 2% if you can if you have 11% then obviously that extra 4% will be hard to get/save at short notice.
have you found a place or area you are interested in? make sure you view as many homes as you can including ones you don't like that much to cross off things you definitely don't want. view homes in the price bracket lower and higher so you can see the difference in what you get for your money.
i initially was looking at spending as little as possible on my first home. i then upgraded to next bracket and then the bracket after that after i saw them. so i went from a 2-3 bed flat to looking at small 3 bed detached to large 3 bed detached with large driveway and attached garage, etc.
i was looking for around 2 years before i bought. i'm glad i spent all that time researching and i ended up making the best choice. the home i have now could do me for life or the next 10 years. whereas before they would have been stop gaps.
pictures can be deceiving and i even looked at semi-detached to rule them out. the bedrooms were far too small. i looked at old houses and ones less than 20 years old. i wouldn't cross off a new build but generally speaking IMO it depends on the area. I know in my area new builds are overpriced. in an area 5 mins away they are a good price and will 100% go up in value with time. in my area they won't due to them being overpriced in the first place.
Did it all online via nationwide. Had to drop in proofs at a branch but doing it all online by myself was a breeze. Intact Buying my flat was very easy and stress free. I’ve rcerntly remortgaged and that was super easy well.
I was a FTB, with no chain which made it easy I suppose. However, don’t assume it’ll be a headache/difficult!
I would also recomend first direct, we got AIP online (was easy) and did the rest over the phone. We got a great deal and five year fixed term and can make unlimited over payments with no penalty. They beat almost every other provider on the rate by a bit as well which was handy
Getting on the electoral role is good for your credit score.
Other than standard advice paying off your credit cards etc (make sure all minimum payments are met even if it's 0%).
Looks like you have a long way to go if youve got very little in savings (a couple years for deposit?) , but good luck!
Also Lloyds bank today launched a 100% £0 deposit mortgage, fixed for 3 years at 2.99%.
It requires family to put up a 10% deposit that is locked in a savings account for the same period, but it does pay 2.5% interest.
Actually a very attractive offering if you have family who can help. It is also low risk to them.
Is there any scope for your wife to earn more? Is it a new business that's starting up? If she was on a minimum wage FT job, assuming you're over 25, she'd have 17k income, which might boost your available amount to maybe 210/215.
Sadly I don't think we have a couple of years, so will no doubt have to rent.
Great eh? Yet some people are able to get houses given to them because they're jobless and up the duff
Are you currently at parents/in laws and rent free? Just try save as much as possible/earn as much as possible.
I don't think others living in naff council housing is something either to aspire to or relevant
. Bit of a daily mail comment![]()
Aye sounds good, just no one is available to give that kind of money sadly
Any family member willing / able to take out a loan and put the funds in said savings account? You could have an agreement where you cover the interest portion of any loan they get so that they benefit and you guys still get a big boost to getting on the property ladder?
Thankshaha, nice long reply
Yep, it's a help to buy ISA, I've only been able to put the minimum in over the last year, hence why it's not gone up a lot
Going by what you're saying, we can't get much unless we get a significant fund from somewhere, pretty much everyone we knoe only managed to get their houses and deposits due to a grandparent t passing away basically....
As for prices, they'll be around 240k more than likely, we may need to move further out into let nice areas annoyingly, or do shared ownership :/
Unless more business comes in, no.
New business, well, been going for a couple of years but she's been self employed doing other work for about 4/5 now I believe.
I have suggest trying to find at least a three day a week job, to get some extra, but most of those dont pay much sadly
