It's is tough - really tough, a deposit takes years to build, even if you live like a monk.
Shared ownership can be an option, but has its own risks...
Aye, something we've considered, she just hates new builds...but it may be something we have to do
Or keep your payments the same, take advantage of the better LTV and thus interest rate and shorten the term.
That’s the approach I took, payments went up by £50~ but my term is almost 10 years shorter now than when I bought the house 3 years ago.
Aye, if you can comfortably pay it off at the same rate, why not?
Also if you have any unused credit cards with zero balances then look at cancelling them and only keep 1 or 2. I'm looking to buy (first time) and had over £50k of available credit available. I was advised by my broker that lenders can be scared by this, so cancel the ones you don't need.
Thanks. Yes I only have the two, one I clear every month the other has less that 2k to clear - I'm aware this probably needs to shift first
Before buying make sure that you dont stretch your budget to the absolute limit, make sure you have some spare cash every month in case the house needs maintenance.
For 90-95% LTV HSBC seems to provide one of the best rates and their online process is very simple. You can try making an application online just to get an agreement in principle, hsbc doesnt carry out a hard check on your credit history for this (or nationwide, these are the two I tried less than 6 months ago).
The only advantage of going with a mortgage broker is if you are self employed and they sometimes offer a cashback with their lenders but definitely not worth paying them for, as you can pretty much apply to most banks directly. If you are buying through an estate agent they might try and persuade you to use their advisors.
Wife is self employed, so may be worth looking at a broker and normal advisor?
Also to claim on the H2B ISA, the house value has to be under 250k. One of my mates went just slightly over and hence couldnt use the ISA bonus.
Yes, I've noticed that. There are some ways 'around' it.
