My FTTC is 7 ms.Thank you. I appreciate the mileage will vary a bit but that's so much better than my current ping on an FTTC service. Think once my contract is up I'll be going VM.
In reality you'll notice zero difference between 7 ms and 17 ms.
4ms at work against bothMy FTTC is 7 ms.
Try wired first as it may be the VM network itself.
I couldn't stream 1080p YouTube but Speedtests showed speed was fine.
Has it been installed yet? Would really appreciate you doing some tests of the throughput as I'm giving consideration to going back to Static from Dynamic
Funny enough been with virgin just before chrismas after changing from sky sky is terrible I’m currently getting 200mb for £37 a month but this months is 100 for a reason it didn’t say that in the TnCs
What I mean is it says £37 a month why is the first bill double? This month was suppose to be 62 with the activation fee somehow it was 100..
I got an install date — 7th of Feb. Hopefully, everything works out OK, and it'll be set up pretty quickly. I can't see it taking too long all they need to do is switch the router/modem and do some line tests.
Bit cheeky to be honest. If not, they'll install another piece of kit (not sure of it's name as engineer didn't need one) that will take some of the upstream bandwidth to put onto the down speed. Surprised them by having a full collection of all the attenuators
